Configuration |
Configuring an OPC UA Driver is similar to configuring an OPC Driver. To configure it, right-click this object and select the Select Server item.
Select server option
The following window is then displayed, allowing to select an OPC UA server on a local machine or on a network.
Local and network OPC UA servers
For each OPC UA server, locally or on a network, endpoints are enumerated, which can use different protocols and security modes. In addition, for each endpoint a server can also support different ways of identifying and authenticating users.
Currently, Elipse Power allows a connection only using the Binary TCP mode. For this mode, Elipse Power supports security modes defined by the OPC UA standard, with several combinations of security policies. For authentication, Elipse Power only supports Anonymous and User and Password modes.
NOTE |
The OPC UA Servers window lists all protocols and security modes, for user information. However, only Elipse Power compatible modes can be selected. |
When selecting an Elipse Power compatible endpoint, the EndPointURL, SecurityMode, and SecurityPolicy properties of this object are automatically filled in.
If the UserName and Password properties of this object are left blank, Elipse Power uses an anonymous connection with a server. Otherwise, Elipse Power sends these property values to a server, which must support that type of authentication on the selected endpoint.
In this object users can configure several time-outs for an OPC UA connection. These time-out limits (the TimeoutCall, TimeoutConnection, and TimeoutSession properties) are always in milliseconds and they must be set according to communication performance, which may be limited by a server, by a network, by machines executing a client and a server, and even by operations performed on a client. These settings must be performed on a case-by-case basis and these property values are only suggestions.
In Elipse Power Studio, communication with a Driver can be activated by selecting the Activate Communication option on object's contextual menu. Activation is performed automatically by Query objects when selecting servers, Tags, or when performing a visualization of query results on the Visualize tab.
NOTE |
The Activate or Deactivate Communication option implies in a sufficient number of licenses for all OPC UA Tags and OPC UA Block Elements available in an OPC UA Driver. If there is no sufficient licenses for all Elements of an OPC UA Block, the whole OPC UA Block does not communicate. Please check topic Licenses for more information about this behavior. The activate option is only available if the EndPointURL is configured. |
Notice that to edit Driver properties it may be necessary to deactivate communication. If communication is active in Elipse Power Studio, then users can open a window with information about the selected server (by selecting the Information About Server option on object's contextual menu). In case a connection is not established, for any reason, this window displays question marks instead of server information.
