Licenses |
Users can view all available licenses via E3 Admin. To do so, right-click E3 Admin's icon on Windows Notification Area and then select the Licenses option. The window on the next figure is then shown.
E3 Admin - Licenses window
Available options on the E3 Admin - Licenses window
Option |
Description |
Key Number |
Informs the number of a protection device, an eight-digit hexadecimal number with an "HL" prefix if the device is a hard key or a sixteen-digit hexadecimal number with an "SL" prefix if the device is a soft key. If no protection device is detected, then this number is filled with zeroes |
E3 Server |
Indicates the type of E3 Server |
Elipse Power Studio |
Indicates the number of available and in use Elipse Power Studio licenses |
Elipse Power Viewer |
Indicates the number of available and in use Elipse Power Viewer licenses |
Elipse Power Viewer Only |
Indicates the number of available and in use Elipse Power Viewer licenses in Read-Only mode |
Substations |
Indicates the number of available and in use Substation licenses |
Feeders |
Indicates the number of available and in use Feeder licenses |
Power Measurements |
Indicates the number of available and in use Elipse Power Measurement licenses |
Wind Turbines |
Indicates the number of available and in use Wind Turbine licenses |
Photovoltaic Arrays |
Indicates the number of available and in use Photovoltaic Array licenses |
Inverters |
Indicates the number of available and in use Inverter licenses |
Power Flow Inputs |
Indicates the number of available and in use Power Flow Input licenses |
Load Shedding Breakers |
Indicates the number of available and in use Load Shedding Breaker licenses |
Modeled Loads in Power |
Indicates the number of available and in use Modeled Loads in Elipse Power licenses |
Modeled Loads for Schematic View Generation |
Indicates the number of available and in use Modeled Loads for Schematic View Generation licenses |
Loads for State Estimator |
Indicates the number of available and in use Load for the State Estimator module licenses |
Loads for Distribution Model |
Indicates the number of available and in use Loads for Distribution Model licenses |
Self-Healing Breakers and Reclosers |
Indicates the number of available and in use Self-Healing Breaker and Recloser licenses |
Remote Domain (Server) |
Indicates the number of available and in use Remote Domain (Server) licenses |
Remote Domain (Client) |
Indicates the number of available and in use Remote Domain (Client) licenses |
I/O points |
Indicates the number of I/O points |
Storage tags |
Indicates the number of Storage Tags |
Drivers |
Indicates the number of available and in use Drivers |
OPC Server |
Indicates the number of available and in use OPC Server licenses |
Maximum execution time |
Indicates the maximum allowed execution time for an application |
TrendAnalysis |
Indicates the number of available and in use licenses of the TrendAnalysis object |
HASP service |
Indicates the version of the service for accessing licenses (HASPLMS) |
For more information about Elipse Power's Demo mode limitations, please check topic Limitations of Demonstration Mode.
NOTE |
•Users logged in and identified as E3DataAccess and E3AccessLayer, the Program column on the Logged in users list, do not consume Elipse Power Viewer licenses from an E3 Server. •Changes in the N1 to N4 properties of I/O Tags and in the B1 to B4 and Size properties of I/O Blocks consume licenses. •Changes in the ItemID property of OPC Tags, OPC Blocks, OPC UA Tags, and OPC UA Blocks consume licenses, as well as changes in the Size property of OPC Blocks and OPC UA Blocks. •For the previous cases, it is recommended to deactivate these objects in scripts, by using the Deactivate method, execute these changes, and then reactivate the objects by using the Activate method. |
