Server Objects as Alarm Areas
Server objects have the possibility of behaving as Alarm Areas. These objects have an additional tab, Alarms Area, where this behavior can be enabled and configured. The next figure shows that tab on an I/O Driver.
Alarms Area tab
Alarms Area tab
Available options on the Alarms Area tab
Option
Description
Work as Alarms Area
Enables or disables an Alarm Area behavior for a Server object. This option corresponds to the IsAlarmArea property of an object
Check alarms
Enables or disables Alarm check on an object. This option corresponds to the AlarmVerify property of an object
User fields
Please check topic User Fields Settings for more information
Other information about the functionality of this object's properties can be found on Elipse Power Reference and Scripts Manual, in its respective chapter.
