PowerEngine and Electrical Studies |
•Fixed a behavior of the Self-Healing Module where triggers without a path to Generators with good quality tripped with success. This bug occurred since v5.0.361.
•Fixed an incorrect error code returned by the Self-Healing Module when there is no solution for a trigger. This bug occurred since v5.5.108.
•Fixed the mechanism that aborts a trigger analysis if the time passed is greater than the value of the TriggerAnalysisTimeout property of the Self-Healing Module. This bug occurred since v5.0.431.
