Other Implementations |
•Created the IsObjectActive property, which indicates whether a native Elipse Power object is active or not.
•Now the process PowerEngine2.exe, which executes Electrical Studies for EDB modules, is also monitored by E3 Server, periodically registering its CPU and memory usage.
•Added to log an information of when Elipse Power, client or server, is using a non-standard TCP/IP port, that is, other than 6515 on connections.
•Logs of RECRaw session were redesigned.
•Elipse Power Studio grids now display a tool tip for cell values with hidden or partially hidden text.
•Added in the Full log the registry keys FullLogComCalls, to enable recording all DCOM calls received, and FullLogRecCalls, to enable recording all REC calls sent and received.
