Studio |
•Added shortcut keys in Elipse Power Studio for the Saves and Runs the Domain (F9), Run or Stop Domain (SHIFT + F9), and Run or Stop Elipse Power Viewer (CTRL + F9) options.
•Added options to access Elipse Knowledgebase, Elipse Software channel on YouTube, and Elipse Software Driver's download page on Elipse Power Studio's Help menu.
•When creating or saving an object, a Folder, or a Resource, Elipse Power version used to save them is now registered. When executing an application, saved versions of every object are registered on logs.
•Elipse Power Studio now displays a warning to users in case they try to add a library copied from an existing one. In addition, the Domain Verifier is now opened when finding errors in a Domain when executing an application.
•Elipse Power now uses the Common Controls 6.0 library.
•Standardized the size of text and date and time edition boxes to fit a Spin Button.
•Removed the single tab on WatchWindow window.
•Implemented a new shortcut for the Show in Editor command, a double-click or press the ENTER key on an item in Organizer or Explorer.
•Created shortcut keys for Elipse Power Studio windows (Organizer, Gallery, Properties List, etc.).
•Changed the terminology for the Domain or Object Verification.
•The configuration window of Digital, Analog, Table, and Multiple Links now allows receiving keyboard focus using shortcut keys CTRL + ENTER and ALT + Down arrow when focus is on Link's row and column.
•Created the DeleteFile method to delete objects from project files by script in Studio.
•Implemented new styles or themes for Elipse Power Studio and changed the default theme.
