Elipse Power Data Objects |
•Added the RemoteControlType, HasLoadShedding, and HasSelfHealingControl properties to Breaker and Recloser objects, and the RemoteControlType property to the Switch object.
•Created the objects Wind Power Plant, Wind Turbine, Wind Weather Station, Bay, Converter, Rotor, Transmission, Transformer, Nacelle, Tower, Yawing, Generator Terminal, Grid Terminal, Generator, Meteorological, Blade, Hub, Generator Rotor, Generator Stator, and Terminal.
•Changed the behavior of the GetMeasurement method of Power objects, to allow using Strings to specify a Measurement terminal.
•Added the Retentive property to Discrete and Analog measurement sources.
