PowerEngine and Electrical Studies |
•Added the SpinReserveMode property on Electrical Study Load Shedding, which allows adjusting the load shedding algorithm's functionality.
•Prevented the triggering of Self-Healing module on overloads when the solution found is to open the Switch that started that triggering.
•Fixed the behavior of the Self-Healing module, which was admitting current values with bad quality, if the penultimate sample of current had a good quality, its values were the same, and the timestamp of the penultimate sample was less than 12 hours of the local time.
