Installation |
•Added the Release Notes file in Spanish in the installation e3full-x86-esn.exe. This bug occurred since v3.2.242.
•Corrected Spanish translation problems in E3Alarm and Alarm Server objects, and in Elipse Power Studio.
•Tested the compatibility of RMChart with Internet Explorer 6, 7, and 8. In IE8 there is a workaround: Access the option Tools - Internet Options. In the Advanced tab, section Security, uncheck the option Enable memory protection to help mitigate online attacks. After restarting IE8, a WebViewer with an RMChart is correctly loaded.
•Corrected a problem in the installers, which caused a rollback in the installation when the files ped.exe, scrwiz.dll, ped.hlp, htmlr000.htm, htmlref2.htm, index.htm, and vbsref.htm were not present during the configuration of the Microsoft ActiveX Control Pad component. This bug occurred since v3.0.268.
