<< Click to Display Table of Contents >> RemoveFrom |
RemoveFrom(idElement, idFrom)
Removes the element indicated by the idElement parameter from the Bay or Transmission Line indicated by the idFrom parameter. This method returns a Boolean indicating whether this operation is successful or not.
NOTE |
For more information about the format of the idElement and idFrom parameters, please check the ID property, common to all devices. |
