<< Click to Display Table of Contents >> ID |
Unique identifier of a device in the electrical model. This value is usually imported from the electrical model, and cannot be changed at run time. When in the Electrical Modeler, this property is automatically assigned by the system, and it is a read-only property.
NOTE |
The value of this property is a GUID String, such as "{6B29FC40-CA47-1067-B31D-00DD010662DA}". For devices that do not belong to the electrical model, the value of this property is "{00000000-0000-0000-0000-000000000000}". |
