Elipse Power |
•Fixed a problem when normalizing large angles during the import of BusBar objects. This bug occurred since v3.5.81.
•Fixed a load shedding occurred when an unbalanced power error of an island was less than 5%. This bug occurred since v3.5.226.
•Fixed a problem of losing values from BusBar properties, when some of its Busbar Terminal objects were outside BusBar boundaries. This bug occurred since v3.5.288.
•Changed the find and replace behavior of Power Configuration tabs, to not open and activate the editor when replacement is performed with option Replace All. This bug occurred since v3.5.236.
•Fixed Connector and Branch behavior when moving their Terminals with the SHIFT key pressed. This bug occurred since v3.5.127.
•Fixed a non-conformity when using a Connector or Branch when the CTRL key was pressed. This bug occurred since v3.5.81.
•Fixed a GPF that occurred when entering a Substation or Feeder, and mouse pointer was over a Connector. This bug occurred since v3.5.226.
•Fixed a reconnection problem on PowerExplorer's Measurement tabs. This bug occurred since v3.5.81.
•Fixed a problem in the Electrical Modeler, which cut a Bay but not its elements. This bug occurred since v3.5.141.
•Fixed a problem of not zeroing the reactive power of ZIP-type Loads on Power Flow. This bug occurred since v3.5.81.
•Fixed a problem in Electrical Modeler, which did not received keyboard focus when its tab was activated. This bug occurred since v3.5.81.
•Fixed the behavior of Command Unit's Interlocked property when there is Interlocks in objects of its upper hierarchy, before activating the Unit. This bug occurred since v3.5.81.
•Created an error window in Elipse Power Studio with messages of recording failures on electrical model files. This bug occurred since v3.5.81.
•Elipse Power Studio now displays an error window when a failure during the reading of an electrical model file occurs. This bug occurred since v3.5.81.
•Fixed the handling of changing Discrete Measurements' MeasurementType property, at run time. This bug occurred since v3.5.81.
•Fixed the behavior of TAB and SHIFT + TAB key combinations, when PowerExplorer is opened inside a WebViewer. This bug occurred since v3.5.81.
•Fixed synchronicity during import of Elipse Power's Screen objects, which generated wrong Links when the synced data object was inside a Folder. This bug occurred since v3.5.228.
•When there is more than one object with the same ID in Elipse Power, and one of them is synced, the other ones are zeroed, and are no longer reused during data object syncing. This bug occurred since v3.5.136.
•Fixed the validation of values in Rotation property of Electrical Modeler objects, which did not converted correctly very high value to a scale between 0 (zero) and 360 degrees.This bug occurred since v3.5.81.
•Minimized a problem in Electrical Modeler, which forced the selectable area of an object with high zoom to become larger than the object's real area. This bug occurred since v3.5.81.
•Included in Electrical Modeler a Label object on LinkNode symbol, which indicates to which Feeder or Substation it is connected. This bug occurred since v3.5.81.
•Fixed a problem in Electrical Modeler, in which the target was displayed when mouse was over a Terminal, even when the selection tool was enabled. This bug occurred since v3.5.127.
•The Electrical Modeler now does not allow cutting LinkNodes anymore. This bug occurred since v3.5.141.
•Fixed a problem in Electrical Modeler, where DisplayX and DisplayY properties were not set immediately, in case the object was moved using the keyboard. This bug occurred since v3.5.141.
•Fixed a problem in Electrical Modeler, when rotating an object very close to Bay's border, parts of the object remained outside the Bay. This bug occurred since v3.5.81.
•Fixed the behavior of Busbar's Rotation property in Electrical Modeler, which now converts automatically the value of that property to the interval between 0 (zero) and 360 degrees. This bug occurred since v3.5.81.
•Fixed a problem in Electrical Modeler, which displayed an error message when resizing a Busbar using left handles until it finds a Terminal. This bug occurred since v3.5.288.
•Fixed a problem in Electrical Modeler, in which an object dragged so that mouse pointer moved outside Modeler's screen, and then returned to screen, a selection box appeared where the object started being dragged. This bug occurred since v3.5.305.
•Fixed the behavior of object selection in Electrical Modeler, which remained static when the object was dragged with the CTRL key pressed. This bug occurred since v3.5.127.
•Fixed the behavior of Electrical Modeler, which always selected the same Terminal when a Connector or Branch connecting the Terminals of the same object. This bug occurred since v3.5.290.
•Fixed a problem in Electrical Modeler, which when moving a handle quickly, mouse pointer and handle lost connection. This bug occurred since v3.5.81.
•Fixed a problem in Electrical Modeler, in which it was difficult to rotate a Terminal very near to the Busbar border. This bug occurred since v3.5.81.
•Fixed the Electrical Modeler, which did not allow selecting a Connector or Branch placed between two Breaker Terminals, after that Breaker was selected or resized. This bug occurred since v3.5.81.
•Fixed a problem in Electrical Modeler when adding Vertexes in a Connector, because sometimes the Vertex was inserted on another location. This bug occurred since v3.5.81.
•Fixed the positioning of the text of a Busbar object in Electrical Modeler, which was created superimposed, thus making it hard to read. This bug occurred since v3.5.142.
•Fixed a problem in Electrical Modeler when dragging objects outside the edition area, releasing mouse button, and then moving the objects again. Their arrangement was slightly different. This bug occurred since v3.5.81.
•Fixed a problem in Electrical Modeler, which allowed to continue to move a Busbar Terminal, even after changing the selection by using the TAB key. This bug occurred since v3.5.81.
•Created minimum (approximately 1e-99) and maximum (approximately 1e99) limits for Electrical Modeler's FontSize property. It was also fixed the behavior of F7 and F8 keys when these limits were reached. This bug occurred since v3.5.81.
•Fixed a decrease in performance during property changes on applications with many objects. This bug occurred since v3.5.141.
•The Topology Processor and Voltage Color modules of the Electrical Modeler were optimized to improve performance during edition. This bug occurred since v3.5.81.
•Fixed a problem with the Connector tool that remained enabled even after using the TAB key. This bug occurred since v4.0.192.
