TabsEnabled
TabsEnabled
Number Allows configuring which tabs are visible on a PowerExplorer window. If this window is already open, these tabs are immediately updated. This property accepts a combination of the following values:
1: Displays only the Analog tab
2: Displays only the Discrete tab
4: Displays only the Command tab
8: Displays only the Protection tab
For example, the value 3 (three) displays Analog and Discrete tabs and hides Command and Protection tabs. The value 12 displays Command and Protection tabs and hides Analog and Discrete tabs. The special value -1 (minus one, default) always displays all tabs. The value 0 (zero) is not accepted, that is, users cannot hide all tabs, which generates a script error.
