Link Edition
Link Edition
Elipse Power contains a tool to edit Links, named Edit Links. With it, users can edit one or more application Links more quickly than using a traditional window.
To use this tool, right-click one or more objects and select the Edit links option.
Edit Links option
Edit Links option
The dialog box on the next figure is then displayed.
Edit Links
Edit Links
The previous dialog box shows a list of Links, Link-type properties, and user events related to the selected objects and their child objects. According to a row type, information to display on columns are described on the next table.
Available options for Edit Links window
Option
Description
Object's name
Determines object's name
Property / Event
Determines the object's property that contains this Link
Connection
Determines a Link type, Simple, Bi-directional, Digital, Analog, Table, Reverse, or Multiple
Source
Determines a Link's source
Options for Link-type properties
Option
Description
Object's name
Determines the name of the object that contains this property
Property / Event
Determines property's name
Connection
It is always the same, Link
Source
Determines property's value
Options for User events
Option
Description
Object's name
Determines the name of the object that contains this event
Property / Event
Determines the name of a user event
Connection
Determines an event type, OnEvent, WhileEvent, or OnValueChangeEvent
Source
Expression related to this event
On the Edit Links dialog box, users can modify the following options:
Links: Can be modified, except for object's name
Link-type properties: Can be modified, except for object's name
User events: Can be modified, except for object's name and event's name
By clicking Remove Remove the selected Link, users can remove the selected Link. The Show links properties window option determines whether Link minidialogs are displayed when a row is selected. If this window is visible, then users can edit Link properties. Its default value is enabled.
NOTE
On the Edit Links window, users can keep a Link with an empty source. To do so, select the Source column and press the DELETE key.
Editing properties of the selected Link
To edit user event properties, it is necessary to select a row containing the event and, on Connection column, click the Edit option.
Editing user event properties
When clicking the Edit option, the dialog box on the next figure is displayed, thus allowing to edit the selected user event.
Edit events window
Edit events window
Available options for Edit Events window
Option
Description
Property or expression
Property or expression generating this event
Whenever the property/expression is true
Indicates whether this is an etOnEvent- or an etWhileEvent-type
Repeat event
Indicates the cycle for event repetition in milliseconds, that is, its periodicity while an expression generating it remains true
Repeat every (ms)
Value for a repetition interval, in milliseconds
Whenever the property/expression changes its value
Indicates that this event is an etOnValueChangeEvent-type,that is, this event occurs whenever the expression that generates it changes its value
Treat disconnection as value change
If there is a disconnection, it is handled as a value change
The Edit Links window allows using copy and paste features among property Links. The Copy Link option copies a Link from the selected row and the Paste Link option pastes that Link to the selected row, replacing the previous Link.
Option to copy or paste a Link
