Bi-directional |
A Bi-directional Link is similar to a Simple Link. However, if there is a variation in this property, its value is copied to the source, thus generating a bi-directional Link.
Bi-directional Link
To use this resource, follow these procedures:
1.Select the object for the Link.
2.Right-click this object and select the Properties option.
3.Click the Links tab and select the property to create the Link. Elipse Power Studio indicates several types of Links.
4.In the Source option, select the Link and click to indicate the property to create a reference, or write down an expression in this option.
