Analog Alarm
Analog Alarm
Allows monitoring an analog variable by specifying up to four alarm levels, which are LoLo (Very Low), Lo (Low), Hi (High), and HiHi (Very High).
Analog tab
Analog tab
Available options for the Analog tab
Option
Description
Subcondition
Name of this alarm's sub-condition. Available options are LoLo, Lo, Hi, or HiHi
Enabled?
Enables checking the selected alarm's sub-condition
Limit
Indicates a level in which this alarm's sub-condition is triggered
Message Text
Allows specifying a text displayed to users when this alarm's sub-condition is active
Severity
Determines a severity for this alarm's sub-condition. Available options are Critical, High, Medium, or Low
Need Ack?
Enables or disables the acknowledgment of this alarm's sub-condition
Event?
Enables or disables handling this alarm's sub-condition as an event
Allow shelving?
Enables or disables shelving this alarm's sub-condition
Shelve maximum duration
Maximum time, in minutes, this alarm's sub-condition can remain shelved. Default value of this option is 60, that is, one hour
Maximum shelve count
Maximum number of times this alarm's sub-condition can be shelved. Default value of this option is 0 (zero), that is, no limit
Delay (ms)
Specifies a delay time, in milliseconds. When this value is equal to 0 (zero, default), no delay is applied
Deadband
Enables a dead band, which is a feature used to avoid a variable, when oscillating around an alarm's limit, to generate an unnecessary number of messages
Return message
Allows specifying a text displayed to users when this alarm is not in an active condition
