Open Screen Pick |
Let's implement navigation among application Screens. Each button on Menu_Screen must open its respective Screen on Frame's central area.
1.On Menu_Screen, select the Command Button identified as "SE1" and, at the bottom, select the Scripts tab.
2.On Click event, create a new Open Screen-type Pick.
3.In the Open Screen field, select the SE1_Screen item and, in the In Frame field, select the Central_Area item.
Open Screen Pick
4.Configure the Command Button identified as "Events" to open its respective Screen.
