Indication of Local and Remote
1.Open the SE1_Screen and insert a Display near Breaker 52-02.
Display
Display
2.Right-click this Display and select the Properties option. On the window that opens, select the Links tab.
3.In the Value property, use the AppBrowser to select, on Source column, the Discrete Measurement LocalRemote, on Measurements folder of Breaker 52-02. On the right, select the Value property and click Paste.
4.Configure the link as Digital and define its value according to the next figure.
Value property
Value property
5.Execute the application. Toggle the value of this Measurement between Local and Remote, and check if Display's text shows that information correctly.
CHALLENGE VIII
When there is one or more unacknowledged alarms in a Substation, text of button SE1 on Menu_Screen must blink with another color.
TIP
Use the ActiveNACKAlarms property of the Substation object.
