Local or Remote
Local or Remote
The Local/Remote command template does not exist as a default in Elipse Power, so users must register it.
1.Select the Commands tab of a Power Configuration object.
2.Click Add Add and select the Discrete Command option. Configure the following properties:
Electrical Phase: 1 - epNone
Description: Local/Remote Command
Sorting: 1000
3.Click Add Add to create Semantics, according to the next figure.
Creating Semantics
Creating Semantics
4.On Substation SE1, right-click Breaker 52-01 and select the Add - Commands option.
5.Add a Discrete Command on Commands folder. Configure the following properties of this object:
CommandType: LR (on the combo box)
6.Add two Command Units to Command cmdLocalRemote: "Remote" and "Local". Do not forget to configure the CommandName property of these Units.
7.On Tag column select, using the AppBrowser, the SE1.[52-01].Measurements.LocalRemote.Operator item for Units Local and Remote.
8.Execute this application and test this new Command.
CHALLENGE VI
Create a Step Command to control Tap position of Transformer TR-01.
TIP
Use Command *TapPosition, which is Elipse Power's default.
