Properties |
For references to object properties, users must use the GetObject method. Its syntax is the following:
Application.GetObject("<object>").<property>
Where <object> is the name of an object, and <property> is the name of a property, as in the next example.
Application.GetObject("Data.TempTank2").Type
For an easy typing, it is always advisable to use AppBrowser, which already retrieves the correct syntax.
