GetObject |
GetObject(ObjectPath)
This method returns a reference to the object specified by ObjectPath. This allows accessing all object's properties and methods. This is a common practice when programming scripts in Elipse Power, makes it easy to handle objects, and makes code more intelligible. Example:
Sub CommandButton1_Click()
' Assign the value 20 to InternalTag1's Value property
' which is inside Data.
Set tag = Application.GetObject("Data.InternalTag1")
tag.Value = 20
