ShowPowerExplorer
ShowPowerExplorer
ShowPowerExplorer(Title, RootObject, [Left], [Top], [ReadOnly], [ScreenObject], [BKColor], [ShowObjHierarchy])
Displays a window with all Analog and Discrete Measurements, Commands, and Protections of the selected object. This method's parameters are listed on the next table.
Parameters of the ShowPowerExplorer method
Parameter
Description
Title
Determines a window's title. Corresponds to PowerExplorer object's Title property
RootObject
Data device's path
Left
Window's horizontal coordinate, in pixels. Please check PowerExplorer object's SetWindowPlacement method for more information about this parameter's behavior, if omitted
Top
Window's vertical coordinate, in pixels. Please check PowerExplorer object's SetWindowPlacement method for more information about this parameter's behavior, if omitted
ReadOnly
Allows changing or not Measurement values with the ActiveSource property equal to 2 - Operator (Discrete or Analog), and also sending Commands. Corresponds to PowerExplorer object's ReadOnly property. If omitted, allows changing Measurement values and sending Commands
ScreenObject
Informs the graphical object associated to this method, highlighting its terminals. Corresponds to PowerExplorer object's ScreenObject property. If omitted, does not associate PowerExplorer's window to any graphical object
BKColor
Background color of the Display containing Measurement, Command, and Protection values. Corresponds to PowerExplorer object's DisplayBkColor property. If omitted, uses Windows default background color
ShowObjHierarchy
Indicates whether a tree must be displayed with the hierarchy of child objects of the object that called the PowerExplorer object. Corresponds to PowerExplorer's ShowObjectHierarchy property. If omitted, does not display a tree with the hierarchy of child objects
Usage example:
Sub Button1_Click()
  Application.ShowPowerExplorer "Breaker 5201",_
    "SE1.[5201]", 100, 100, False,_
    Screen.Item("Breaker5201"), RGB(0,0,0), False
NOTE
PowerExplorer's properties can be configured in the object returned by Viewer's GetPowerExplorer method.
