ActiveSource
ActiveSource
Enum Measurement Source used as active by the object. Possible values for this property are the following:
1: SCADA
2: Operator (default)
3: Control Center
4: Billing
5: Calculated
6: Database
100: Topological Processor
101: Power Flow
102: State Estimator
103: Load Shedding
104: Distribution Load Modelling
105: Self-Healing
106: External Reader
The selected Source type must exist in the Measurement to be set as active. It is not possible to select types 100, 101, 102, 103 , 104, 105, or 106 (Electrical Study outputs) if the StudyInputSource property is set to 0 (ActiveSource). In case the selected Source is deleted, this property assumes a value of 2 (Operator).
