StudyInputSource
StudyInputSource
Enum Determines the active source for the Electrical Study. Possible values for this property are the following:
-1: None (default)
0: Active Source
1: SCADA
2: Operator
3: Control Center
4: Billing
5: Calculated
6: Database
The selected source type must exist in the Measurement to be set as an Electrical Study input. If this property is set to 0 (ActiveSource), it follows the configuration performed in the ActiveSource property. It is not possible to select type 0 (ActiveSource) if the ActiveSource property is set to 100, 101, 102, 103, 104, 105, or 106 (Electrical Study outputs). In case the selected source is deleted, this property assumes a value of -1 (None).
