ItemID
ItemID
Text Specifies the path to perform a browsing of an OPC UA Block Tag on an OPC UA server. This path is used in OPC UA Driver's RefreshUaNodeIds method to retrieve an OPC UA Node Identifier of an OPC UA Block Tag, when needed.
