ProtectionMode
ProtectionMode
Enum Receives an integer value from a *ProtectionMode-type Measurement, as if it were a shortcut to the Measurement value. This property informs which Protection mode is configured:
0: Excluded
1: Included
2: Blocked
3: Test
4: Test and Blocked
This property makes it easy to create objects (Screen or data) that need information about the Protection mode, by simply reading this property, instead of searching for a Protection's child object. This is a read-only property.
