DeleteSemantic |
DeleteSemantic(Index)
Removes a Semantic object indicated by the Index parameter from the collection of Command Type Semantics (returned in the Semantics property), if it exists.
NOTE |
Command Types created by default (which contain the character of an asterisk at the beginning of their names) and Step Commands do not accept removing their Semantics. A Discrete Command always contain a Semantic, which cannot be removed. |
