Semantics
Semantics
Collection This property returns an object that allows configuring Command Type Semantics by script. Command Type Semantics are available on the Commands tab of the Power Configuration object. To use the object returned by this property at run time, users must deactivate the Power Configuration object before changing their properties.
NOTE
Please check topic Semantics for more information about the properties of the object returned by this property.
