WriteSyncMode
WriteSyncMode
Enum Determines how writings are sent to the I/O Server (synchronous or asynchronous mode). This property contains the configuration options described on the next table.
Available options for the WriteSyncMode property
Option
Description
0 - wsmDefault
Synchronous mode (default)
1 - wsmSync
Synchronous mode. Every time a value is written to an I/O Tag, E3Run sends the writing to the I/O Server and waits for the return of that writing
2 - wsmAsyncUnconfirmed
Asynchronous mode without confirmation. All writings are sent to the I/O Server without waiting their return, and it is always assumed that writing was successful. When in asynchronous mode, I/O Tag's writing methods, Write and WriteEx, always return True immediately, and writing status, on methods returning this status, remains always empty. I/O Driver's OnTagWrite event is executed as soon as the writing is sent to the I/O Server, and the Succeeded parameter always remains in True
Asynchronous writings are executed by the I/O Server as soon as this I/O Driver is available, when the current reading finishes. If several asynchronous writings are sent to the I/O Server, this I/O Driver only resumes readings after all asynchronous writings are executed.
