OnTagWrite
OnTagWrite
OnTagWrite(Tag, Succeeded, User)
Occurs when a writing operation is triggered on any I/O Tag.
OnTagWrite event variables
Name
Description
Tag
A reference to the I/O Tag object being written. For example, users can access the I/O Tag property using a syntax such as Tag.DocString
Succeeded
A Boolean value indicating whether a writing operation was successful or not
User
Parameter that receives the name of the user performing the writing operation. Default value of this parameter is "System". If there is no user logged in the Elipse Power Viewer generating this event, this parameter contains the value "Anonymous"
