Login |
On Menu_Screen, insert a Command Button object and change its Caption property to "Login".
1.Select the button's Scripts tab and add a script.
2.On the first line, type the following comment:
'User login
4.On the second line, open AppBrowser and select Viewer's Login method.
'User login
Application.Login()
5.Execute the application and test this new functionality.
