E3Browser
E3Browser
1.Insert an E3Browser E3Browser on Event_Screen.
2.To configure data displayed by this E3Browser, open its properties window and select the Query tab.
3.Select Query1 and click Configure.
Query tab
Query tab
4.Select the Database containing the table to query.
5.Select the Alarms table.
6.Select the fields needed to display on screen. If all table fields are needed, click the asterisk (*).
Alarms table
Alarms table
7.Open the Visualize tab and click Execute Query Execute Query to check Query's result.
Execute Query
Execute Query
8.Click OK. After finishing this step, all fields listed on the Query are available in E3Browser. Configure each field with the desired color, format, and size.
Field configuration
Field configuration
9.Execute the application and open Event_Screen to test this new functionality.
CHALLENGE XIII
Change E3Browser to display texts "Yes" and "No" instead of "0" and "1" for the Acked column, which indicates that an alarm was acknowledged.
