Statistics |
To help on viewing Electrical Study licenses, the Power Configuration object contains a tool called Statistics, which displays the counting of relevant objects for each Study license. To access this tool, right-click the Power Configuration object and select the Electrical Model - Statistics option.
The window on the next figure is then displayed. This window only lists objects relevant to the calculation of licenses for different Electrical Studies.
Model Statistics window
For Power Flow licenses, the counting is displayed at the end of the table, on the Total inputs item.
For all other Electrical Studies, information appears detailed in the Load Shedding, State Estimator, Distribution Load Modeling, and Self-Healing fields.
