Event Causes |
The next table contains detailed descriptions about event messages containing a %CAUSE% macro.
Messages of events with a %CAUSE% macro
Event |
Default Message |
Example of %CAUSE% |
User login '%USER%' in %SESSION' in '%MACHINE%' failed: %CAUSE% |
•Incorrect login or password •Disabled account •Blocked account •Expired password •Error code in hexadecimal format, such as 'error 0x1234abcd' |
Domain has been changed by user '%USER%' in %SESSION% in machine '%MACHINE%': %CAUSE% |
•Project 'projectname' added (enabled) •Project 'projectname' added (disabled) •Project 'projectname' removed •Project/library 'projectname' renamed to 'newname' •Project 'projectname' moved •Project 'projectname' enabled •Project 'projectname' disabled •Changes applied in Domain editor window |
User '%NAME%' was modified by '%USER%' on machine '%MACHINE%'. '%CAUSE%' |
'option' modified from 'oldvalue' to 'newvalue'. Please check table Options of the Edit User window for examples of messages |
Group '%NAME%' was modified by '%USER%' on machine '%MACHINE%'. '%CAUSE%' |
'option' modified from 'oldvalue' to 'newvalue'. Please check table Options of the Edit Group window for examples of messages |
System Events Recording modified by '%USER%' in %SESSION% in machine '%MACHINE%': %CAUSE% |
'option' modified from 'oldvalue' to 'newvalue'. Please check table Options of the Events Recording tab for examples of messages |
Domain Security modified by user '%USER%' in %SESSION% in machine '%MACHINE%': %CAUSE% |
'option' modified from 'oldvalue' to 'newvalue'. Please check table Options of the Security tab for examples of messages |
Option |
Data Type |
Example of Message |
This is an administrator user |
Boolean |
'User is Administrator' modified from 'Enabled' to 'Disabled' |
Disallow password change |
Boolean |
'User cannot change their password' modified from 'Default' to 'Enabled' |
Password expiration |
Boolean and Integer |
'Time (in days) until the password expires' modified from 'Default' to '1' |
Minimum password age |
'Minimum duration (in days) before a password can be changed to a new one' modified from 'Default' to '1' |
Minimum password length |
'Minimum number of characters that the password must have' modified from 'Default' to '1' |
Alphanumeric password |
Boolean |
'Password must have letters and numbers' modified from 'Default' to 'Enabled' |
Minimum numeric characters in password |
'Minimum number of numbers that the password must have' modified from 'Default' to '1' |
Minimum letters in password |
'Minimum number of letters that the password must contain' modified from 'Default' to '1' |
Minimum special characters in password |
'Minimum number of special characters that the password must contain' modified from 'Default' to '1' |
Uppercase and lowercase characters |
Boolean |
'Password must have uppercase and lowercase letters' modified from 'Default' to 'Enabled' |
Account disabled |
Boolean |
'This account is disabled' modified from 'Disabled' to 'Enabled' |
Account blocked |
Boolean |
'This account is blocked' modified from 'Disabled' to 'Enabled' |
Force password change |
Boolean |
'User must change their password in the next login' modified from 'Disabled' to 'Enabled' |
Ignore case in passwords |
Boolean |
'Check passwords without validating upper- and lower-case letters (not recommended)' modified from 'Default' to 'Enabled' |
Password history |
'Number of recently used passwords by a user and that can not be reused' modified from 'Default' to '1' |
NOTE |
When changing the password of a user in Elipse Power Studio, by using the Users item on the Users and Groups window of File - Users menu or by using Viewer's UserAdministration method, the event message is "User 'username' was modified by 'anotheruser' in machine 'computername'. 'User password was changed'". |
Option |
Data Type |
Boolean |
Boolean |
Boolean |
Boolean |
Password history |
NOTES |
•For more information about the Edit User window, please check topic Users on chapter Security. •For more information about the Edit Group window, please check topic Groups on chapter Security. •Options with a Default value on a message indicates that the value of that option is inherited from Domain's general options. |
Options of the Events recording tab
Option |
Data Type |
Example of message |
Enable system events recording |
Boolean |
'Enable system events recording' modified from 'Enabled' to 'Disabled' |
Table name |
String |
'Table name' modified from 'Table1' to 'Table2' |
Automatically select application database |
Boolean |
'Use this Database' modified from 'DB1' to '(automatically select)' |
Use this database |
Boolean and String |
'Use this Database' modified from 'DB1' to 'DB2' |
Event |
Boolean |
'eventname' modified from 'Enabled' to 'Disabled' |
Options of the Security group on the Properties tab
Option |
Data Type |
Boolean |
'User cannot change their password' modified from 'Disabled' to 'Enabled' |
Boolean |
'Password must have letters and numbers' modified from 'Disabled' to 'Enabled' |
Boolean |
'Password must have uppercase and lowercase letters' modified from 'Disabled' to 'Enabled' |
Boolean |
'Check passwords without validating upper- and lower-case letters (not recommended)' modified from 'Disabled' to 'Enabled' |
Username and password must differ |
Boolean |
'User name and password cannot be the same' modified from 'Disabled' to 'Enabled' |
'Minimum number of characters that the password must have' modified from 'Disabled' to '6' |
'Time (in days) until the password expires' modified from '2' to 'Disabled' |
'Minimum number of numbers that the password must have' modified from 'Disabled' to '2' |
'Minimum number of letters that the password must contain' modified from 'Disabled' to '3' |
Password history |
Automatic user blocking |
'Number of failed logins to block user account' modified from 'Disabled' to '1' |
Automatic user account unblocking |
'Time (in minutes) to automatically unblock the user' modified from 'Disabled' to '1' |
Password expiration warning |
'Time (in days) to warn the user before the password expires' modified from 'Disabled' to '1' |
