Browsers |
The Elipse Mobile can be accessed directly via a web browser using an address in the format http://server_ip
/, for example http://127.0.0.1:8080/. It is also possible to access an application using the server computer's name on the network, such as http://localhost:8080/.
NOTE |
The default TCP/IP port used by Elipse Mobile is 8080. To change this configuration, please check topic Server Settings. |
