Server Settings
Server Settings
To configure Elipse Mobile Server, right-click the Elipse Mobile Server Elipse Mobile Server icon on Windows Notification Area and select the Settings option.
Server tab
Server tab
The available options on the Server tab are described on the next table.
Available options on the Server tab
Option
Description
Enable secure connections
Enables a secure connection to the Server
Security certificate (.crt)
Indicates a connection's secure certificate file. Click Import to import a file with a .crt extension
Private key (.key)
Indicates a connection's private key file. Click Import to import a file with a .key extension
HTTP
Indicates the TCP/IP port used by an HTTP connection. Default port for HTTP connections is 80
HTTPs (secure)
Indicates the TCP/IP port used by an HTTPS connection. Default port for HTTPS connections is 443
NOTES
•Please check topic Firewall Settings for more information about configuring TCP/IP ports.
•To create a test certificate for HTTPS connections, please check article Generating a test certificate for HTTPS on Elipse Knowledgebase.
•Please check article Available trusted root certificates for Apple operating systems for a list of pre-installed trusted root certificates on iOS operating system.
Smtp tab
Smtp tab
The available options on the Smtp tab are described on the next table. These options are used to send e-mails to users and administrators, such as when users forget their passwords. These settings are used regardless of the client.
Available options on the Smtp tab
Option
Description
Server
Address of an SMTP (Simple Mail Transfer Protocol) server
Port
TCP/IP port of a server. Default port for SMTP servers is 587
From
Name of an e-mail sender
Sender email
Address of an e-mail sender
Connection
Type of connection to a server. Possible values for this option are Start not encrypted (default), Encrypted (TLS), or Not encrypted
Authentication
Type of authentication. Possible values for this option are Using HMAC_MD5, No authentication, Normal Password, or Encrypted Password (default)
User
User name
Password
User password
Send test e-mail
Click to send a test e-mail using the configured options. This message is sent to the e-mail configured on the System User tab
System User tab
System User tab
The available options on the System User tab are described on the next table.
Available options on the System User tab
Option
Description
Redefine credentials
Select this option to redefine the credentials of a system administrator user, defined in the User and Password options
User
User name of a system administrator
Password
Password of a system administrator
Email
E-mail address of a system administrator, used to receive important status information about the server
The About tab shows information about Elipse Mobile Server version and all libraries used.
About tab
About tab
Server configurations are saved to a file called init.json, located on the installation folder of Elipse Mobile Server. This file contains configurations not available on the tabs previously described. The next table contains configurations that can be changed directly on this file.
Available options on the init.json file
Option
Description
admin_login_email
Enables the system administrator to receive an e-mail whenever they perform a login. The default value of this option is false
crossajax
Enables Elipse Mobile Server to accept connections from another server. Possible values for this option are true or false. Default value of this option is false
nthreads
Indicates the size of the pool of threads of Elipse Mobile Server. The more simultaneous users, the larger the value of this option. Default value of this option is 24 and its minimum possible value is 8 (eight)
securityversion
Configures a minimum HTTPS protocol acceptable by Elipse Mobile Server. Possible values are 0: Accepts SSL 2 and later, 1: Accepts SSL 3 and later, 2: Accepts TLS 1 and later (default), 3: Accepts TLS 1.1 and later, or 4: Accepts TLS 1.2 and later. It is recommended to always use the latest protocol version
servername
Name of the Telegram's reference server for sending messages
server_url
The URL of the Elipse Mobile Server instance. This option is used in the external authentication by OpenID to identify what protocol should be used (http or https).
by sysadmintelegram
Indicates the identifier (id) of the system administrator's Telegram account.
A way to discover the IDs is by using TelegramWeb. When you open the chat of the group/user to which you want to send the message, the corresponding ID is shown alongside the website address, for example: https://web.telegram.org/a/#-4226494617
telegrambot
Indicates the Telegram bot token used to send messages.
Sample: "bot6730154057:AAEQHPzbNJWqueMRM3xnDIjUHsBkQUUAAAA"
For information on how to create a bot on Telegram, access the official documentation (https://core.telegram.org/bots#how-do-i-create-a-bot).
two_factor_authentication
Requires a two-factor authentication from all users when a new device is registered. The limit of registered devices per user is 2 (two). When a new device is registered, the oldest device is removed. The default value of this option is false. Please check the next note and text for more information about this option
NOTE
A two-factor authentication is not required from users created with a unique device and system administrators.
Two-Factor Authentication
Whenever a user logs in a device not yet registered in Elipse Mobile Server, an e-mail is sent to this user with a code. That code must be provided on the login screen to finish the registration of this device. The maximum expiration time for this code is 1 (one) minute. The maximum number of devices registered in Elipse Mobile Server is 2 (two). Whenever a new device is registered, the oldest registered device is removed. When a user executes a login on a device already registered, the two-factor authentication is not required, only when that user executes a logout. System administrator users are advised to configure the admin_login_email option to true to receive an e-mail whenever they execute a login.
