Command Prompt Options |
Elipse Event Log Viewer can be used on a Command Prompt. The usage format to open log files is described next.
eelogviewer file1.etl[;file2.etl[;file3.etl]]
The format for executing commands is described next.
eelogviewer [- | /] [option]
The options for the option parameter are described on the next table.
NOTE |
Some of the next commands must be executed with elevated privileges, by using the Run as Administrator option on Elipse Event Log Viewer's contextual menu. |
Available options for the option parameter
Option |
Description |
? or help |
Displays a message box with a help text about all Command Prompt options |
install |
Installs Elipse Event Log Viewer |
uninstall |
Uninstalls Elipse Event Log Viewer |
q |
Quiet mode. It does not display any dialog box with error messages |
singleton |
Prevents opening several instances of the same process in which Elipse Event Log Viewer is executing |
resetwindows |
Returns all settings for windows and columns of Elipse Event Log Viewer to their default |
uiPlacement <value> |
Defines how child windows of Elipse Event Log Viewer's main window are displayed. Possible values for the <value> argument are Empty: The child windows are opened on the last position they were opened, regardless of the monitor where Elipse Event Log Viewer's main window is currently located (default) or trackMainWindow: The child windows always open on the monitor where Elipse Event Log Viewer's main window is located. Please check the next note for more information about the behavior of this option |
Using the uiPlacement option does not open Elipse Event Log Viewer, only toggles between the available behaviors to open child windows of the main window. These behaviors are only effective the next time Elipse Event Log Viewer is opened. |
When using the ? or help command on the Command Prompt of Elipse Event Log Viewer, the window on the next figure is displayed.
Help window of Elipse Event Log Viewer's Command Prompt
