Objects of a Section Report
A Section Report contains several objects that can be used, available on its toolbar. The available options on this toolbar are described on the next table.
Available options on the toolbar of a Section Report
Option
Description
Load RPX File Load RPX File
Imports a Section Report configuration from an external file in RPX format
Save as RPX File Save as RPX File
Exports a Section Report configuration to an external file in RPX format
Select Select
Enables a selection mode of objects
Move Forward Move Forward
Sends an object to the front of another object. The selected object is placed on the first position in the layer order
Move Backward Move Backward
Sends an object to the back of another object. The selected object is placed on the last position in the layer order
Line Line
Basic straight line object that connects any two points. It allows drawing lines, by specifying two points when creating it or in polygons
Rectangle Rectangle
This object allows drawing rectangles, using the whole object's width or height. It is created by using at least two vertexes
Rounded Rectangle Rounded Rectangle
A Rectangle created by using two vertexes with an option of rounding its edges by using a round factor. When inserted or edited, it shows a small point next to its upper left edge, which allows modifying that round factor
Ellipse Ellipse
This object allows drawing circles and ellipses, by using the whole object's width or height, and by defining the center of the circle at rectangle's center
Picture Picture
This object allows displaying images stored in files, whether they are inside or outside the application file
Text Text
Allows creating a text. When defining the area on a Screen, users can directly type a text, which also accepts multiple lines
Field Field
By using this object, users can link it to a table field in a Database. This field is specified by the DataField property
Check Box Check Box
Allows inserting a Boolean data type, which may or may not be bound to a Database
Barcode Barcode
Allows generating a picture that converts a sequence of numbers and characters into a bar code. This code is a numerical or alphanumerical representation, used to facilitate different processes. This code is recognized by scanners and optical-reading devices
Page Break Page Break
Sets a point where a page finishes and another one starts on a Section Report. For example, users can force a page break to force a chapter title to always start on a new page
Chart Chart
This object is used to view Section Report's data in a graphical format. For more information, please check chapter Charts and E3Chart
NOTE
The Printer option on E3 Server icon on Windows Notification Area displays a list of printers found either locally or remotely, and allows users to select one for use by an E3 Server.
