Detail
Detail
The Detail Section is the body of a Section Report, printed once for each data source's record. For this application, alarm's data is displayed.
1.In the Detail Section, insert a Field Field object for each record, aligning it with its respective text. In their DataField and Text properties, type the exact column's name configured in the Query.
2.To preview this Section Report, click Preview Report Preview Report.
NOTE
If there are unwanted spaces between data rows, change the CanShrink property of the Detail Section to True.
