Section Reports
Section Reports
A Section Report is a component called E3SectionReport, which allows viewing and printing snapshots of values from system variables and data stored on a database, such as Alarms, Historic objects, Queries, and Formulas. To use a Section Report, right-click the View - Reports item in Organizer, in Domain mode, select the Insert Section Report in option, and then the project's name.
A Section Report uses a Query object. This object allows specifying a data source from a database to display in a Section Report.
A Section Report contains several Sections. Each Section of a Section Report contains a group of controls that are processed and printed at the same time, as a unit.
Sections of a Section Report
A Section Report is structured as described on the next table.
Structure of a Section Report
Section
Description
Report Header
This Section prints at the beginning of a Section Report. It is used for printing headings, sum tables, charts, or any other information that must appear only at the beginning of a Section Report
Report Footer
This Section prints at the end of a Section Report. It is used for printing sums, grand totals, or any other information that must be printed once at the end of a Section Report
Page Header
This Section prints on top of every page of a Section Report. This is the first Section printed on a page, except when this page contains a Report Header Section. It is used for printing column headings, page numbers, page titles, or any other information that must be printed at the beginning of every page
Page Footer
This Section prints once at the bottom of every page of a Section Report. It is used for printing page totals, page numbers, or any other information that must be printed once at the bottom of every page
Detail
This Section is the body of a Section Report, which prints once for every record on a data source
Group Header, Group Footer
A Section Report may have multiple nested groups. Each group contains a Header Section and a Footer Section. A Header Section is printed right before any Detail Section in this group. A Footer Section is printed right after a Detail Section in this group
The toolbar of a Section Report contains configuration items that allow editing, viewing a Section Report, and creating scripts. These items are described on the next table.
Configuration options on the toolbar of a Section Report
Option
Description
Preview Report Preview Report
By using this option, users can preview an output of a Section Report. With it, they can check margin settings and images, for example
Configure Report Configure Report
This option allows users to configure Page Settings, Preview Settings, Style Settings, and Global Settings
Scripts Scripts
By using this option, users can edit scripts for a Section Report. In the Object field, users must specify the object to create the script, and in the Events field, the Section Report event where that action occurs
