<< Click to Display Table of Contents >> Simple Link |
1.To simulate movement of tank's liquid on SynopticScreen, create a Link between the VerticalPercentFill property of tank's cut and the Value property of Level1 Tag.
2.Repeat the procedure of the previous item for the second Rectangle object, linking the Value property to the Level2 Tag.
1.Create a Link in the temperature Display of each tank with its respective Tag.
Value property
