WindowResizable
WindowResizable
Boolean Indicates whether a window can be resized. This property is effective only if the WindowBorder property is set to True. The default value of this property is True. This is a read-write property, but changing its value at run time does not change settings for an already opened Elipse E3 Viewer, only for windows opened using Elipse E3 Viewer's settings.
