<< Click to Display Table of Contents >> LoginUser |
LoginUser(Username, UserPassword, [OpStatus], [WarnDaysToExpire])
Executes a login operation for a specific user without displaying any message. The Username parameter is a user's name and the UserPassword parameter is the password for that user. The optional return parameter OpStatus is a map of bits indicating the status of that operation and the optional return parameter WarnDaysToExpire indicates the number of days until UserPassword expires. This method returns a Boolean indicating whether the operation failed or not. Please check the next tables for more information about possible values in case of failure.
NOTE |
This method is only available if the logged-in user belongs to an Elipse E3 Domain. |
Possible return values for the OpStatus parameter
Description |
0x000000 |
No error |
0x000001 |
Unspecified error |
0x000002 |
Incorrect user or password |
0x000004 |
The current password must be changed |
0x000008 |
The current password expired |
0x000010 |
This user's account is blocked |
0x000020 |
This user's account is disabled |
0x000040 |
The RPC server is not available |
0x000080 |
Authentication mode not supported |
0x001000 |
Password not informed |
0x002000 |
This user has no permission to change their password |
0x004000 |
The informed password is not alphanumerical |
0x008000 |
The informed password does not contain upper and lower case letters |
0x010000 |
The informed password is too short |
0x020000 |
The informed password does not contain the minimum number of numbers |
0x040000 |
The informed password does not contain the minimum number of letters |
0x080000 |
The informed password does not contain the minimum number of special characters |
0x100000 |
The informed password is equal to the user's name |
0x200000 |
The informed password was recently used |
0x400000 |
The current password did not reach its minimum duration |
Possible return values for the WarnDaysToExpire parameter
Description |
-1 (minus one) |
This password is outside the expiration interval or it never expires |
0 (zero) |
This password expires today |
n |
This password expires in n days inside the configured expiration interval |
