GetTrendAnalysis
GetTrendAnalysis
GetTrendAnalysis([Title])
Returns an object that allows configuring a TrendAnalysis window. The Title parameter indicates a title, optional, for the TrendAnalysis window. If this parameter is omitted, the TrendAnalysis window receives the expression "TrendAnalysis". In a script, users must use this method according to the next code.
Sub
  Set TA = Application.GetTrendAnalysis("TrendAnalysis Window")
For more information about properties and methods of this object, please check topic TrendAnalysis.
