<< Click to Display Table of Contents >> DomainState |
Indicates the Domain status on the remote server. Possible values for this property are -1: Closed or without a Domain, 0: Stopped but loaded, 1: In Hot-Standby mode, or 2: Executing. Usually the value of this property is the same value of the State property of the Domain Information object if the other server has the same Domain loaded. This is a read-only property and is only available for the RemoteServer object.
