<< Click to Display Table of Contents >> ServerMachine2 |
This property determines the address of the station where the redundant OPC Server is executing, for cases in which the connection to the OPC Server indicated in the ServerMachine property fails or takes a time longer than the specified in the ConnectionTimeout property. The connection to this redundant OPC Server is only possible if the ServerStatus property is equal to 1 (one, ServerStatus_Running).
