ServerStatus
ServerStatus
Enum Determines the status of an OPC Server connection. This is a read-only property. The available options are described on the next table.
Available options for the ServerStatus property
Option
Description
-1 - ServerStatus_Unknown
The OPC Driver is connected to an OPC Server but either status is not informed or OPC Client's ReconnectPeriod property is set to zero (default)
0 - ServerStatus_NotConnected
The OPC Driver is not connected to an OPC Server. This happens when, for example, an OPC Driver is not active, or a connection was not established yet for any reason
The following values are only informed when the ReconnectPeriod property is different from 0 (zero). This time period specifying a status is retrieved from the OPC Server. In case this status is not correctly informed, this property can maintain its value in -1 (minus one), or the disconnection can be detected in this case, which brings this property to 0 (zero). Values are based on the five default status types defined for OPC Servers.
Available options for ReconnectPeriod different from zero
Option
Description
1 - ServerStatus_Running
OPC Server is executing normally
2 - ServerStatus_Failed
OPC Server is not executing. An unspecified error occurred on the OPC Server
3 - ServerStatus_NoConfig
OPC Server is executing, but without information about its configuration
4 - ServerStatus_Suspended
OPC Server was temporarily suspended
5 - ServerStatus_Test
OPC Server is in test mode
The next script contains an example of using this property.
Sub CommandButton1_Click()
  Dim status
  status =  Application.GetObject("OPCDriver1").ServerStatus
  MsgBox "Driver status is " & status
  Select Case status
    Case -1
      MsgBox "OPC Driver is connected to the OPC Server_
        but its status was not informed."
    Case 0
      MsgBox "OPC Driver is not connected to an OPC Server."
    Case 1
      MsgBox "The OPC Server is running normally."
    Case 2
      MsgBox "The OPC Server is not running."
    Case 3
      MsgBox "The OPC Server is running without information_
        on its configuration."
    Case 4
      MsgBox "The OPC Server has been temporarily suspended."
    Case 5
      MsgBox "The OPC Server is running in Test Mode."
  End Select
NOTE
To obtain a behavior equivalent to a Boolean property, it is recommended to use this property different from 0 (zero). This basically differentiates only between having or not having a connection, without considering more specific OPC Server statuses. In addition, this expression does not depend on using the ReconnectPeriod property different from 0 (zero).
