Picture This property specifies a picture (bitmap) set to an object. A picture file can be selected via Properties List or via scripts, by using the LoadPicture function to specify a file path and name containing this picture. To remove a picture, click the value of this property and press the DEL key. The BACKSPACE key does not delete a picture.
