<< Click to Display Table of Contents >> HideSelection |
This property specifies whether the selected text is still highlighted when an object does not have focus anymore. If this property is set to True, the selected text is not highlighted, unless this object has focus. Otherwise, the selected text always appears highlighted. The default value of this property is True.
