<< Click to Display Table of Contents >> Locked |
This property enables or disables object edition. If this property is set to True, edition is not allowed. Otherwise, users can edit the object. Values configured for the Enabled property influence the behavior of this property. For more details, please check the Enabled property. The default value of this property is False
